EX-L v6 Oil Consumption - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > the 9th Generation
Old 02-17-2013, 12:11 PM
terrapin terrapin is offline
So I checked the oil in the Accord today and w/ 1300 miles on it the dipstick is showing I need to add oil. Has anyone else experienced oil consumption like this?
Old 02-17-2013, 12:17 PM
Motocrafted_7.5's Avatar
Motocrafted_7.5 Motocrafted_7.5 is offline
Home is where the work is
Yes, Read..
http://honda-tech.com/showthread.php?t=2867654
http://www.topclassactions.com/lawsu...action-lawsuit
http://www.carcomplaints.com/Honda/A...sumption.shtml
My Heat Reflector Cold Air Intake system will add 10 hp and 5 lb " of torque down low and up high!! (Patent Pending!!) Yes, it was born out of a Home Creepo mod!!!
Old 02-17-2013, 12:26 PM
Sorry I meant consumption with the 2013 V6. I did see a bunch elsewhere online for previous generation engines
Old 02-17-2013, 12:30 PM
Read it anyway. You might either have a lemon or your accord uses oil but Honda gets to determine what acceptable level of oil usage is. So read it anyway...
Old 02-17-2013, 12:34 PM
namegoeshere's Avatar
. . . . ლ(ಠ益ಠ)ლ . . . .
Did you check the oil level when you first got the car? If not, maybe it was low to begin with.
Old 02-17-2013, 12:42 PM
Yep, checked after I purchased the car and then again around 700 miles and the level was at the full mark.
Old 02-17-2013, 01:35 PM
MN_Runner MN_Runner is offline
4th Gear
This could be VCM related
I asked the question a few weeks ago but no one responded. http://www.driveaccord.net/forums/sh...ad.php?t=79794
Keep track of the oil consumption and let them know. I think 1 qt per 1200 miles is within the spec although not a good deal for you. Odyssey had oil consumption related to VCM equipped models. Do not change the factory oil until you hit 5-10% on your V-6. I heard via Odyclub.com that oil consumption was minimal after the first oil change. They change the piston rings around 2012 V6 because of oil consumption.
Old 02-17-2013, 03:38 PM
JB3 JB3 is offline
2nd Gear
I have 3,000 miles on my 13 Accord V6 and the oil is still almost to the top of the full / add area on the dip stick, probably at about 90% full in the full add area on the dipstick. Check your oil in the morning before you start the engine and you'll notice about half a quart more oil in the moring than if you check it just 1 or 2 minutes after you shut the engine off. Best to check in the morning because checking just one or two minutes after shuting off engine can lead to overfilling which is not good for your engine.
Old 02-25-2013, 02:35 PM
ssmtsx ssmtsx is offline
4th Gear
Send a message via AIM to ssmtsx
I have 3600 miles on my accord and I am down half a quart. I'm going to stop by the dealer and have them check it. I think its within spec though.
Old 02-25-2013, 03:14 PM
4th Gear
How do you know it is a 1/2 qt low? Did you add some oil? If you change your oil every 3000 miles like some oil freak, you would never notice any consumption.
Old 02-25-2013, 04:23 PM
Something Aweso Something Aweso is offline
4th Gear
So are the 2013's experiencing this as well? what crap. From what i read, the oil issues are caused by the use of VCM. The accord does not have VCM? It has an econ button so that eco mode is entered into manually and voluntarily. Is that not right?
Old 02-25-2013, 04:30 PM
Dudley's Avatar
Dudley Dudley is offline
4th Gear
The Accord does have vcm, though the mt may not - it didn't used to.
'13 Alabaster Silver Accord EX Sedan I4 6MT
'07 Graphite Accord SE Sedan I4 5MT
'90 White Integra RS Hatch I4 5MT
Old 02-25-2013, 04:40 PM
robert4 robert4 is offline
2nd Gear
I have noticed that my 2013 V6 is very sensitive to how level the car is when checking the oil. The oil pan is fairly flat and shallow so this is not surprising. I use a very flat and level place to check my oil. My car was perfectly filled when new. At 3500 miles the oil was at half way in the cross hatched area. Now at 5100 miles it has used only the slightest bit more oil so I'm happy with the oil use rate on this car.
With the oil at this half way point, I notice that if checked at a gas station, the level can easily read below the add mark if the car is at all leaned to the left and/or nose high. I wonder how many "oil consumption" problems are due to errors in checking the oil level correctly.
2013 EXL V6 Nav white
Old 02-25-2013, 04:48 PM
Dudley's Avatar
4th Gear
Absolutely. I can see .5 qt diff just from crown of the road.
Old 02-25-2013, 05:01 PM
4th Gear
I checked the oil after it had been sitting for two days. I wont be driving the accord for a few days so I will top it off after its been sitting for a while.
