16.29 MPG Accord 2007 - Drive Accord Honda Forums
Old 02-24-2013, 10:06 AM
hh2004 hh2004 is offline
I recently bought a second hand Honda Accord 2007 (139000 KM ODO). I have changed the engine, transmission oils and done the fuel injector cleaning.
The fuel consumption I calculated for my car is around 16.29 MPG during city driving. Is it normal or do I need to do some checking?
Thanks
Old 02-24-2013, 10:12 AM
drhallsoffice's Avatar
drhallsoffice drhallsoffice is offline
Out & Proud since 2005
Mine averages 21-23 mpg mixed driving. I've seen 30 on a roadtrip, but never below 20mpg at any point. Sounds like some investigating is required.
2003 Honda Accord Coupe
EX-L 3.0L -- Nighthawk Black Pearl
Joined family July 2012 at 66k (Current car)
1998 Toyota Camry
LE 2.2L -- Super White
90k - 177,xxx (Passed down to fiancé, still in my family)
1991 Accord Sedan
LX 2.2L -- Seattle Silver
2 miles - 245k (Passed down from father to myself, sold in 2009)
Member of the 200k Honda Club 9/06/2008 with my 1991 Honda Accord.
Aiming on renewing my status and joining the 300k Honda Club :)
Old 02-24-2013, 10:13 AM
DreaminAccord's Avatar
DreaminAccord DreaminAccord is online now
I <3 My Honda
For both the i4 and V6 engines, that is extremely low (abnormal). My combined city/hwy in my 3.0L V6 is 23-25mpg and I get closer to 29-32mpg when on long highway road trips
This pic was taken 2 days ago - it is a combined city/hwy of 112 miles, I'd say 65% hwy, 35% city - avg 26.9mpg - after yesterday of driving to work (95% hwy) it rose to 29.9mpg
Ben
'07 EX-L V6 Coupe w/ Navi
Graphite Pearl / Black Leather
TL Bi-Xenon Retro | TSX LED Mirrors | Spec-D Fog Lamps | 30% Tint | Alpine Sub System | BlitzSafe AUX | USA Spec BlueTooth
OEM HFP Kit | OEM Visors | Trunk Spoiler | CCD Back-up Cam | Tein Coilovers | Ingalls Camber Kit | H&R TRAK+
Winter: Honda 18" 10-Spokes / Continental DWS
Summer: Hyundai 19" Dual 5-Spokes / Hankook V12 Evo
Old 02-24-2013, 10:15 AM
thanks for the replies...I will take it to the dealer to do a computer scan..
Old 02-24-2013, 10:24 AM
04s-silverk24 04s-silverk24 is offline
how does the engine run? Rough? Smooth? May need new plugs, air filter, pcv valve?
Old 02-24-2013, 10:28 AM
hillstones hillstones is offline
3MTA3
The OP is mixing KM and Miles in his post. Are you converting your KM to Miles when you say 16 MPG? If you run the AC and are heavy on the gas pedal all the time, you can get below 20 MPG, especially in hot summer weather.
Old 02-24-2013, 10:29 AM
I <3 My Honda
Oil leakage, cold weather and/or bad gas can lower your MPG. Also larger wheels/tires.
As silverk24 suggested, bad spark plugs or a leaking/non-functioning PCV valve can also affect your MPG.
Ben
Old 02-24-2013, 10:36 AM
I have changed the air filter but not the plugs. I will change them this weekend. The weather is little bit colder here in saudi arabia and I may be hard on pedal. Engine runs smoothly but i do feel some vibrations when i am in D gear and waiting on red light and ac is on.
Old 02-24-2013, 10:38 AM
namegoeshere's Avatar
. . . . ლ(ಠ益ಠ)ლ . . . .
Originally Posted by hillstones View Post
The OP is mixing KM and Miles in his post..
That, and OP it getting "around 16.29 MPG during city driving." What does OP mean by "city driving," streets only?
How are you calculating MPG? What is your driving style like?
Could be the hot Saudi temps.
Old 02-24-2013, 10:43 AM
I <3 My Honda
Slight vibrations while running the A/C in a 4 cylinder is absolutely normal.
Please inform us, as namesgoeshere suggested, how exactly you are calculating your MPG. One small error in your math can greatly affect the outcome.
1 MPH = 1.609344 KMH
1 US GAL = 3.7854118 LITERS
Personally, I wouldn't just go throwing money into the car, having hopes that it will fix your problem. Remove all of your spark plugs and assess their condition. They may be perfectly healthy and not need replacing yet.
Ben
Old 02-24-2013, 10:54 AM
I put in exact 22.22 liters of fuel in my car. This is worth 10 Saudi Riyals here in KSA. I made the trip A setting to zero at the same time. Now after 154 KM my fuel gauge is exactly at the same level. This gives me 6.93 KM/Liters or 16.29 MPG (US gallons). I am not a hot tempered saudi driver as I am an expat living in KSA for work.
Old 02-24-2013, 11:11 AM
I <3 My Honda
It is not good/very accurate to determine your MPG/KML based upon where the needle-position is on the gauge. Sometimes I can reach the 1/2 tank mark (from Full) after 200 miles, other times it reaches the 1/2 tank mark (from Full) after only, say, 160 miles; but yet my avg MPG in the end is around the same. It's also pretty well known that you get better fuel economy during the first 1/2 of tank than the second.
Did the 22.22L completely fill up/top off your tank? If not, completely fill up your tank and start over; don't forget to reset your Trip computer. Drive until your gas light comes on and then divide the amount of KM you have driven by the amount in Liters it took you to completely fill up your tank again. That will give you a more accurate KM Per Liter ratio - then you can easily convert that to Miles Per Gallon
Ben
Old 02-24-2013, 11:17 AM
Arkainzeye Arkainzeye is offline
4th Gear
what is your tire pressure set at?
Old 02-24-2013, 11:39 AM
I put in exact 22.22 liters of fuel in my car. I made the trip A setting to zero at the same time. Now after 154 KM my fuel gauge is exactly at the same level. This gives me 6.93 KM/Liters or 16.29 MPG (US gallons).
No it doesn't. You cannot accurately calculate your KM/L or MPG like that.
As DreaminAccord said:
1. Go to a gas station and fill up the tank until the nozzle clicks and automatically stops filling. Do not overfill your tank.
2. Reset your trip A meter to zero.
3. Drive until tank is half way empty or more.
4. Fill up the tank again until the nozzle clicks and automatically stops. If possible, use the same gas station and pump. Do not overfill your tank.
5. Write down how many liters of gas you put in.
6. Write down the mileage on trip A meter.
7. Divide the number of KM traveled by liters of gas put in from step # 4. This is your true KM/L (or MPG)
And would you clarify what you mean by "city driving?"
Old 02-24-2013, 12:17 PM
By City Driving I mean my work location is around 6 KM from my home and I have to stop at at least 3 traffic lights on my way to office and same on return. When I return from my office for at least 02 KM I have to drive very slowly due to high traffic. Similarly I some times go out at night for some shopping etc and all the malls are at the same route to my office so around 25 to 30 KM driving everyday with 06 to 09 traffic light stops.
Thanks all for your advise. I will recalculate the fuel consumption by filling the fuel tank full and come back to the forum within few days.
Regards..
