Can not get key out of ignition - Drive Accord Honda Forums
Old 10-09-2006, 08:29 PM
davids2004 davids2004 is offline
Ok a friend of mine is having a problem and I think the ignition switch needs to be replaced.
When she puts the key in it is sometimes hard to go in. It is hard to turn it on and sometimes will not turn to turn on. Sometimes it takes a while to do this. Right now her key is stuck in the ignition and she can not get it out. The key is stuck in the spot were the radio stays on and the key will not come out.
It is a 94 honda accord but not sure on the model.
If it is the ignition switch how hard is this to change?
Thanks.
Old 10-09-2006, 08:53 PM
mnkyman's Avatar
mnkyman mnkyman is offline
6th Gear
did u say abra kadabra?
lol..if it was taking the key out and putting it in, it could do with the steering wheel..and just needing to turn it ...but other than that..im thinking its the ignition part where you put the key in
are u sure the cars in park? alot of cars now days dont allow you to pull the key out if its not in park..but im not sure if thats also the case with a 94 accord
2006 Accord SE LOOKEY
DIYS |- Interior Lights -|- Trunk Cathodes -|
[SIGPIC][/SIGPIC]
Old 10-10-2006, 06:19 AM
bumping this back up
Old 10-10-2006, 06:57 AM
SSMV6's Avatar
SSMV6 SSMV6 is offline
39.1 going on 40mpg!
Give people a chance to wake up first.
I does sound like its a problem with the shifter's gear selector signal. The ignition switch will not let you take the key out unless it "sees" the shifter in Park. I don't have a way to troubleshoot it, though. Did you look at all the fuses to make sure they're ok? That's where I'd start looking first.
2013 Accord EX-L Navi 11,178 miles and counting...
<a href=http://www.fuelly.com/driver/SSMV6/accord target=_blank><a href=http://badges.fuelly.com/images/smallsig-us/210024.png target=_blank>http://badges.fuelly.com/images/smallsig-us/210024.png</a></a> . . . . Last tank mpg = 32.2mpg
2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles
1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles
2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles
Old 10-10-2006, 08:49 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
The most common cause is a worn out key. If you get it out, then try a different one.
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Title goes here
close
video goes here
