Modifying battery tray on 7th gen I4 for bigger batteries? - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Audio & Electronics
Old 12-29-2006, 02:20 PM
Spac3d Spac3d is offline
Hi guys, I am new here to DriveAccord.net.
I was wondering if anyone modified their battery tray in the 7th gen 4cyl to fit a battery bigger than 51. It looks like a D34 is just too big to fit without some sort of mod. Do I just have to cut the plastic? I haven't changed my battery in a while...
I could use a yellow top with more reserve for my car stereo, and they no longer make the 51 yellowtop.
If you can provide pics, I would appreciate it. I searched everywhere.
Old 12-29-2006, 05:18 PM
greg-ster greg-ster is offline
Used to Drive a Hummer H2
Welcome to DA!
The yellowtop D34 will fit in the tray...the tray will just bow outwards a little.
I <3 the princess family!
'05 Hummer Accord EX-L 4cyl/auto Navi
The legendary 20 MPG and Below-er
'07 Toyota Camry XLE V6 Navi/Bluetooth/VSC/Smartkey Sky Blue / Ash
Old 12-29-2006, 07:02 PM
Originally Posted by greg-ster
Welcome to DA!
Did you have to extend any of the cables to fit? It looks like 1 of the power cables may be a tight fit.
My upgraded grounds will be okay.
Old 02-07-2007, 01:44 PM
CA05LXDriver's Avatar
CA05LXDriver CA05LXDriver is offline
5th Gear
Location: Changing the world, one urinal mint at a time!
Was just looking to order the parts to do this!
I was just looking to do this. Apparently the group 35 will fit the v6 tray just fine, so I was going to order the parts below from slhondaparts.com (only 23.28 + tax and shipping). If you look below, the cable is the ground cable, the bolts are the j-bolts, the plate is the strap that goes over the top of the battery, and the box is actually the battery tray.
Part Number Description Quantity Price You Save
32600-SDB-A00 CABLE ASSY. 1 $7.47 $1.75
31513-SP0-010 BOLT A 2 $6.64 $1.56
31512-SDB-A01 PLATE 1 $5.05 $1.18
31521-SDB-A00 BOX, BATTERY (70D) 1 $4.12 $0.96
PRE-TAX TOTAL $23.28 $5.45
Durka Durka
Old 02-16-2007, 01:01 PM
5th Gear
Ordered all parts including Optima... all is on the way. I plan to post before/after shots if anyone is considering upsizing thier battery.
Durka Durka
Old 02-22-2007, 08:21 PM
5th Gear
Update.. bigger battery installed!
Ok, so a couple important notes.
The group 35 battery is a perfect fit if you use the bigger battery box and wider hold down plate (both part #s below). You do not need the longer J-bolts unless you use the 1.5" spacer typically included with optima batteries. I didn't use the spacer because I like the battery as low as I can get it. Also, if you don't use the spacer, you'll need to trim the upper part of the battery box by about 1/2" along the top because otherwise the positive battery cable somewhat interferes with the batt box. If you use a regular (non-optima) battery this wouldn't be an issue.
Also, and an important note even for those who don't plan to use a larger battery, the ground cable that connects to then negative terminal is almost two times larger gauge cable on the V6 model!!!! The part # is also below.
Enjoy!
Durka Durka
