DTC P1456 - EVAP Emissions Control
What damage to the vehicle will result if the cause of this code (P1456 - EVAP Emissions Control System Leakage - Fuel Tank System) is not taken care of?
Is this something I need to have diagnosed and fixed immediately? Thanks! |
| Sponsored Links | ||
Advertisement | ||
Excess fuel consumption, excess emission, and spark plug fouling to name a few... EVAP systems are a PITA to diagnose if it's not something obvious like a loose sealing gas cap.
I'd start with cleaning the filler neck area of rust and cleaning the rubber seal around the gas cap first to see if the problem goes away. BTW, what car is it?
2013 Accord EX-L Navi 8081 miles and counting... YTD avg mpg = 30.22 . . . . Last tank mpg = 29.60 2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles 1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles 2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles |
It's a 2000 LX.
It soiunds like I need to have this taken care of quickly... Well, there goes the new golf clubs. |
Maybe these be of some help.....
We don't tolerate personal attacks!! 3 strikes & you're out!! I kicked cancer's butt! You might be next!!!! :) (_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance. the latest in a long line of Hondas: His: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims |
You could have simply not tightened the gas cap when filling up your car.
I would have the code cleared by Autozone. On my 95 you can remove the radio/ECU backup fuse for about 30 seconds to reset the ECU. I'm not sure about your Accord. Make sure that gas cap is tight and do not overfill your tank. If the error code comes back after resetting your ECU, then you have a problem. Cleaning the threads at the tank and checking the rubber gasket is also an easy and can be a cheap fix to your problem. |
| Sponsored Links | |
Advertisement | |
