Active noise cancellation system - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2005 Honda Accord Instructions
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 01-11-2007, 04:47 PM
domeasour domeasour is offline
I am looking for a document that describes specifically how the ANC system works or any documentation related to this system.
I helped my brother change his speakers (http://www.driveaccord.net/forums/showthread.php?t=5846) and now the ANC system went haywire! every time the car starts the sub woofer makes this very loud sound. They have previously changed the ANC system along with the front speakers. I wanted to know how to turn it off or disable (bypass) it, so that it doesn't make the sub sound.
Here are the specs of what was installed
Kenwood 2 Channel 600W AMP
Pioneer 4 channel 600W AMP
10" pioneer slim sub
Pioneer 4-way 6x9" speakers (pair)
Sony 4-way 6.5" speakers (pair)
Also i don't know if this is a coincidence but about 3 days after we installed it the front lights fuse blew.
perhaps pricess might have some info?
Old 01-11-2007, 05:55 PM
James.uk's Avatar
James.uk James.uk is offline
James.uk
>>>>Active noise cancellation system<<<<
Erm I think thats called an off switch.. Just kidding.. lmho
Honda Accord. 2.0iES 4dr automatic. 1996 'N' reg. 87.000. (Burgandy) ave mpg 21. (Best 32) SOLD.
(modified) Citroen ZX 1.9 Diesel Auto 1994 "L" reg. 100K miles, (Dark Blue), ave mpg 44. (Best 55) ECU free.
2002 Wedgewood blue. Rover 75 2.0 CDTi Conniossaur Auto ave mpg 40 (best 52) mpg. :)
Old 01-11-2007, 06:15 PM
VTECaddict's Avatar
VTECaddict VTECaddict is offline
Out of Control
the ANC system uses a mic in the cabin to "listen" for excess noise and specifically for the noise/vibration caused when VCM shuts off 3 cylinders on the hybrid. when it hears this sound, the system generates sound waves that are complete opposite of the unwanted sound to in effect cancel out the sound. this sound is played back by the head unit though the speakers.
you amp is probably amplifying the reverse waves generated by the ANC. if you disabled the system, you would still hear the deep vibration/booming sound, but coming from the engine instead. has it recently started doing this or has it been this way since the beginning (your other thread is 9 months old).
2006 BMW 330i 6MT (Alpine White/Terra)
Old 01-11-2007, 06:46 PM
Matt-Guy's Avatar
Matt-Guy Matt-Guy is offline
Row Row Row my own gears!
There was some talk about this in the Honda Odyssey forum. They disabled it and they said they noticed no real difference in engine noise gets through. Rather they said it sounds better because the stereo is not producing it. Check it out http://www.odyclub.com/forums/showth...threadid=30221 there.
Old 01-12-2007, 02:12 PM
It did it long ago and the dealer replaced the AMC unit and the front speakers. However, since we just changed the speakers it has been doing it again.
My biggest worry is that it might harm the subwoofer, since its the only thing reproducing the sound.
Old 01-12-2007, 02:38 PM
greg-ster greg-ster is offline
Used to Drive a Hummer H2
This is a '05 hybrid, right?
I <3 the princess family!
'05 Hummer Accord EX-L 4cyl/auto Navi
The legendary 20 MPG and Below-er
'07 Toyota Camry XLE V6 Navi/Bluetooth/VSC/Smartkey Sky Blue / Ash
Old 01-13-2007, 09:41 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
Maybe these can help.....
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 01-13-2007, 09:44 AM
princess's Avatar
ready to go....
or this
Old 01-13-2007, 05:53 PM
TY Princess for those diagrams, they will come in handy!
Update:
When I turn on the headlights or parking lights, there is a low buzzing sound coming from the rear speakers (when the amp is on). it is not a fluctuating sound with different RPMs, therefore it is not cause by the engine.
~90% of the time when I start the vehicle there is a low humming sound coming from the sub, which lasts about 3-4 seconds. While I hear the humming sound, if i accelerate the sound intensifies.
someone suggested that i install a Low/High Converter to replace the speaker level inputs to RCA(high) level inputs. In order to get rid of the buzzing from the rear speakers.
Any ideas? suggestions?
Old 01-14-2007, 12:12 AM
does anybody know where the ANC unit is located? the car is the hybrid model with navi
thanks
Old 01-14-2007, 09:35 AM
princess's Avatar
ready to go....
I found a bulletin....you may have already seen it...
The component location seems to have more than one piece to the noise control system.
Old 04-08-2008, 11:59 AM
ZedsDead ZedsDead is offline
3rd Gear
I have a 2008 Accord Coupe with the same issue.
Has anyone solved this problem (with an aftermarket stereo)? I was simply going to disconnect the microphones but it seems like this will not solve the problem. If anyone has successfully bypassed the ANC system, please please let us know how.
If not, I will when I figure it out (trial and error I guess).
Old 04-08-2008, 12:27 PM
Demonik's Avatar
Demonik Demonik is offline
5th Gear
Send a message via AIM to Demonik
just disconnect the microphones, thats what i did and my sub is fine now
if you have a buzzing/hum going on when the car is on you need to find a better ground
Code:
'08 Honda Accord LX-S // Nighthawk Black Pearl // Black Interior
CURRENT MODS
     6000k 55 watt HID kit // Interior and Exterior LED conversion
     25/15/15 tint // Autozone grille mod
Old 06-03-2008, 04:09 PM
texan444 texan444 is offline
My First Post
2005 Accord Noise Cancellation System Disconnection
Hi,
I live in San Antonio and my girlfriend has an '05 Accord Hybrid with this same noise problem. The dealer says the ANC system is defective and wants to charge her over $500 to replace the control module and the speakers. It sounds like your idea of simply disconnecting the microphone(s) is a good one. May I ask
1) Does the car have one or two microphones (I could only see the one in the front, but you implied there's one in the rear as well).
2) Can you tell me exactly how you got to the microphones (i.e. the exact procedure)?
3) Do you know if there's a fuse devoted strictly to the noise cancellation system? (Perhaps we could simply remove the fuse)
Thanks in advance!
Old 06-12-2008, 08:52 PM
ougrad1 ougrad1 is offline
has anyone solved this yet?
Title goes here
close
video goes here
