Since the first week I have had this annoying tic tic tic rattle that sounds as if it was coming from the A pillar/upper door/dash area.
Unable to isolate by pressing on various trim pieces in the suspect areas.
Worse when cold and on choppy pavement at 25-45 MPH. Of course the dealer could not hear it when I had it in for the software update.
I happened to mention it as a sidebar in a post and Blk9gen asked if it was coming from the airbag cover. BINGO: Problem solved.
It can be correctred by pressing on the left upper seam or by elevating the edge slightly. That only worked temporarily so I cut a piece of bicycle inner tube to cushion the area as a permanent fix.
