Electrical Problems with '03 Accord - Drive Accord Honda Forums
post #1 of 6 Old 04-13-2019, 03:51 PM Thread Starter
CommuteDriver's Avatar
Hi all. Recently my cars (2003 Honda Accord Coupe LX with a 2.4 cylinder engine) electronics have been acting up. I've attempted to make some minor fixes, and do some research on these issues, but at this point I'm stumped. At the moment I'm assuming all of these issues must be related to one another in some way, due to the timing of these malfunctions, but I'm more or less still learning about car maintenance, and I'm unsure if I'm missing something big.
1. My car windows don't work, at all
-From what I understand, typically a faulty window might be because of a power issue, or it could be because of the motor failing. However, I've ruled out a faulty motor because on the day I noticed my power window no longer worked, I was unable to operate any of the windows in the car from the driver side master switch. The window switches on each door have all been tested, and none of them work either. I'm extremely skeptical that all of the motors might have suddenly stopped working at the same time, so I'm ruling that out as a potential issue. All of the door locks still function normally, as do my mirror controls.
2. Speaker problems?
-The second electrical issue is that, while the radio and sound system seems to be getting power (it turns on and doesn't turn off randomly or anything), no sound comes through the car speakers. On a blue moon, occasionally I'll get sound to come through the speakers, but otherwise it's either dead silence or a harsh screech.
3. Overhead cabin light flickers
-After taking a look at the bulb inside the cabin light, it doesn't appear damaged in any way. Despite this, the light flickers repeatedly after it is turned on.
After doing some digging, I started thinking that the multiplexer in my car might be the issue, as I'd noticed other threads with drivers having similar power issues. However, trying to find details about a replacement master control unit on honda parts websites and the like haven't turned up any results. Am I on the right track here? Are all of these problems independent of each other, and I just happened to be unfortunate to have all of these issues crop up around the same time?
CommuteDriver is offline
post #2 of 6 Old 04-13-2019, 04:31 PM
Roll Tide!
jimijam's Avatar
Was this a flood car?
2007 V6 AT Sedan
Go! Fast! A little speed will make ya want a little more.
jimijam is offline
post #3 of 6 Old 04-13-2019, 05:53 PM
My car only has the speaker problems and the overhead light doesnt turn on. Windows still work.
My solution to the speaker is to use my phone and Bluetooth speaker.
PS. Just want to follow this thread
2003 LX I4 Automatic 175k miles
Albert Yip is offline
post #4 of 6 Old 04-13-2019, 06:59 PM
mtts60's Avatar
Bad ground at the light. Pop the cover off and make sure the screws inside are tight and the ground loop(s) are clean. Could also be a corroded switch; easily fixed with some fine sandpaper.
Regarding the speaker and window problems, did they just start or has it always been this way?
- my car's thread
mtts60 is online now
post #5 of 6 Old 04-14-2019, 02:23 PM Thread Starter
Thank you for the responses!
@jimijam: No water damage as far as I'm aware, and from the vehicle history report when I first got the car. I've tried to be as careful as possible not to let water leak into the car, but we do get some pretty heavy rainstorms around here, is it possible some of the wiring was damaged while I was opening the car door during a downpour?
@Albert Yip: I did have Bluetooth functionality installed into the car which was handled by Best Buy a few years back. Worked great up until I randomly started to have issues with the sound. Any recommendations for a portable speaker?
@mtts60: I'll be sure to take a look at the ground just to make sure it's all clear, thanks! The speakers started to malfunction around a year ago. I elected not to make too much of a fuss about it because of the timing, college classes being in full swing and papers being the biggest concern at the time. I mostly just relied on the speakers in my phone. The windows are more recent, and I would say they started having problems around the end of winter, about the first week of January?
post #6 of 6 Old 04-14-2019, 06:27 PM
greg1c's Avatar
My guess is the master window switch, they can get water in them and stop working. You can get them on eBay or Amazon for about $35. The radio is most likely bad connections. I would pull it out and verify everything is connected with solid connections. The light is most likely a loose ground. Do all doors cause the issue?? Do it work normally when you turn it on.
Anker makes a great Bluetooth speaker, you could use that temporarily till you get the radio working properly.
Sent from my Pixel 2 using Tapatalk
Current Honda vehicles
Former Honda Vehicles
2001 Acura MDX Totaled t223k
1995 GSR sold @220k miles
greg1c is offline
Electrical Problems with '03 Accord Coupe-Help? spoonch The 7th Generation 2 03-04-2012 11:08 PM
2004 Honda Accord Electrical Problems Pants116 The 7th Generation 2 10-24-2011 02:24 AM
Few Electrical Problems with 04 Accord RayneMayne The 7th Generation 5 02-21-2011 11:20 PM
Electrical problems 2004 Honda Accord Tourer 2.4 Baselbyt Problems & Solutions 1 06-24-2010 05:06 PM
electrical problems with 1997 accord biglug Problems & Solutions 3 01-21-2009 06:30 AM
