05 Accord Suddenly Wonít Start, Please Help - Drive Accord Honda Forums
  • 1 Post By enne
  • 1 Post By visionguru
post #1 of 7 Old 04-13-2019, 09:50 PM Thread Starter
I drove my car earlier in the morning to run errands and my car worked perfectly fine. Then I got back home and needed to step out hours later only for my car to not want to start. The lights on the dashboard and interior light lit up when I turned the key but thatís it, no power connecting to start up the engine and no revving up sounds.
My neighbor attempted to give me a jump but nothing happened.
This is the first time Iíve had an issue like this since getting my car over a decade ago and I feel like it may be my starter based off of what I read.
Please help. What is the avg cost of repair for this going and whatís the best route to take?
I live in Northern NJ if that helps
Mg8402 is offline
post #2 of 7 Old 04-14-2019, 04:24 AM
Runnin' in the 90s
enne's Avatar
Locate the starter, and tap on it with something like the handle of a screwdriver, or the head of a wrench.
Mg8402 likes this.
1999 Honda Accord LX Sedan 2.3 F23A4 166K Airwrap Jet Black
1989 Honda Prelude Si Coupe 2.0 B20A5 4WS 97k Granada Black Pearl
(Click a name to go to its respective thread)
enne is offline
post #3 of 7 Old 04-14-2019, 05:07 AM Thread Starter
Excuse my ignorance but where is the starter located?
I’m not that car savvy and I’m afraid of going to a mechanic without having some base knowledge as to what may be going on since I’m a woman. I did a bit of research and saw on Autozone that their aftermarket starters are in the $120-200 range, is going that route ok?
Mg8402 is offline
post #4 of 7 Old 04-14-2019, 08:20 AM
visionguru's Avatar
Since you didn't mention V6, I assume it's a 4 banger.
Here is a link for background knowledge:
https://www.hexautoparts.com/blog/Ho...ent-Guide.html
I would start by calling different shops, seeking quotes first. Also, ask questions what kind of parts they use (brand name, remanufactured or new). Generally, mechanics don't allow bringing your own parts. If they do, they often don't provide warranty on their work. Unless you DIY, you might want to use their parts, because labor cost is going to be more than the part.
Mg8402 likes this.
2007 Accord EX-L V6 @155K Alabaster Silver
2016 Audi Q5 3.0T Premium Plus w/Tech Pkg @12K
Previously:
2005 Honda Accord Hybrid ([email protected])
1989 Honda Accord DX ([email protected])
1985 Honda Accord ([email protected])
visionguru is online now
post #5 of 7 Old 04-14-2019, 09:13 AM
Mg8402,
Please don't pull the "since I'm a woman" thing. The first response to your thread was from a woman....she knows more than any ten guys.
Please tell us if you have a 4 cylinder engine or a 6 cylinder engine.
Please tell us the mileage on your car.
Most likely, your car did not start because of a bad ignition switch, a bad starter, a bad battery, or loose and corroded electrical connections. Your issue may simply be that the battery terminals should be cleaned and the cables re-attached.
I went through this last year- I replaced my ignition switch in 20 minutes for about $15.....then I removed and rebuilt my starter in three hours time for under $25. But that was me doing the work.
A Honda dealer would want about $750 to replace your starter. That includes the cost of the part and of labor. An independent garage may charge you $400 for this- but they would use a starter from who knows where.....Ideally, you would want your very own starter to be rebuilt from an alternator/starter rebuild shop. Believe it or not- you do not want a "new" starter- they are mostly imported junk that looks shiny, but most likely will not last long.
The ignition switch is about $65 from Honda, and their dealership mechanics would charge you an hour of labor. What is the going rate in NJ? $120 an hour?
Cleaning and re-attaching the battery connections is a few minutes. Start with this- connections get dirty, and loose. Fixing that is free.
Good luck.
RickBlaine is online now
post #6 of 7 Old 04-14-2019, 04:05 PM
Drew03Accord's Avatar
Originally Posted by Mg8402 View Post
Iím not that car savvy and Iím afraid of going to a mechanic without having some base knowledge as to what may be going on since Iím a woman.
Originally Posted by RickBlaine View Post
Mg8402,
Rick, in her defense, I read that as her seeking knowledge so the mechanics won't easily take advantage, since she's a woman. I've seen it a million times, dealerships and shifty mechanics taking advantage of women.
2003 LX Sedan, i4 + Automatic. 201K and counting.
My toughest oil thread:
Update your sig with your ride here (10 post minimum req):
Maintenance isn't based on milestones. It's ongoing and incremental.
Drew03Accord is online now
The Following User Says Thank You to Drew03Accord For This Useful Post:
RickBlaine (04-14-2019)
post #7 of 7 Old 04-14-2019, 04:36 PM
Drew, you are correct. My apologies. I read it wrong.
93 Accord, engine suddenly dies on highway, won't start (electrical?) civintegraccord The Early Generations 6 10-24-2018 07:27 AM
1999 L4 Eng. SUDDENLY no start - Knock Sensor? PBinLosAngeles The Early Generations 0 03-14-2018 08:43 AM
92' Accord No Start Suddenly Gokussj5okazu Problems & Solutions 1 11-08-2010 09:01 PM
please help please help please help adrammelech The 8th Generation 5 07-04-2009 05:38 AM
v6 suddenly wont start anymore jay6426 Problems & Solutions 8 05-20-2008 02:22 PM
