clunk from park to reverse - Drive Accord Honda Forums
post #1 of 3 Old 05-15-2019, 05:32 AM Thread Starter
Hello,
Recently I noticed that my car makes an audible clunking noise and the car will shutter harder than normal when i shift from park to reverse. shifting to drive or shifting to reverse from drive does not make any noises and has a slight but not concerning shutter as i feel the gears changing. i'm slightly concerned that there could be an issue with the transmission but i wanted to check with others to see if they experience this too or if its normal. I have a 2.0T/10AT. I always come to a stop before changing gears if I am backing up for instance. But there are times where after I shift to drive and take my foot off the brake, the car will roll backwards a little and I'll slowly push the gas to counter the back roll and go forward. I know this probably isn't the best thing to do but I didn't think that would really do anything but maybe it did.
Thoughts from anyone?
garebear is offline
post #2 of 3 Old 05-15-2019, 08:03 AM
I've found that especially if the engine is cold and the idle speed is up, that park to reverse can be a little on the forceful side and also reverse will "creep" a bit faster than i'd like (speed while reversing without applying any throttle) but have not had any issues in over 17k miles, I think its just a quirk of the vehicle.
Once the engine is up to temp and the idle speed is down, it behaves as one would expect it to.
2018 Honda Accord Sport
2.0T/10AT
Platinum White Pearl
rmurad38 is online now
post #3 of 3 Old 05-15-2019, 08:07 AM Thread Starter
This was happening after I had been driving the car for about 40 minutes so it was warm.
garebear is offline
clunk clunk trusaleen1 The 9th Generation 6 03-23-2015 03:47 PM
Transmission, Reverse to Drive Clunk jackoduc The 8th Generation 2 05-16-2012 07:15 AM
Shifting from reverse to Drive, clunk! prime9 The 8th Generation 7 12-14-2010 08:51 AM
"Clunk" noise when shifting to reverse only drivethrufresno The 7th Generation 0 07-11-2010 08:04 PM
Clunk Clunk Clunk... dads-car Problems & Solutions 17 10-31-2005 12:02 AM
