Keep "Automatic" headlights from turning on the high beams? Owner's manual!!!!! - Drive Accord Honda Forums
 3Likes
post #1 of 20 Old 02-28-2019, 09:14 PM Thread Starter
I've been using the "AUTO" setting for the headlights on my 2019 Accord Hybrid. They are very nice to have, except occasionally they turn on the high beams. They usually do that when there are no cars in front of me, which is OK, But then if/when someone comes around a corner ahead and come my way, the car doesn't dim the headlights to normal for a few seconds. So the car that just came around the corner gets a full dose of my highbeams, and then my car puts them down to norm AFTER blinding the car in front of me.
Is there a way to tell it, "Sure, go ahead and turn the headlights on or off when you think they are appropriate... except never turn on the high beams unless I hit the high beam control lever" ?
LilAbner is offline
post #2 of 20 Old 02-28-2019, 09:17 PM
JacobRx's Avatar
Pull on the lever towards you. This changes them from automatic brights to manual brights. Then you'd just have to push the lever away from you to turn on the brights similar to older models.
Sent from my SM-N960U using Tapatalk
JacobRx is offline
post #3 of 20 Old 03-01-2019, 03:40 AM
On pp 197-199 of the owner's manual there's a description of how that system works.
Orlando Cabrera and da35 like this.
2018 Accord EX-L 2.0T 10AT
2017 Subaru WRX 6MT
NH Guy is online now
post #4 of 20 Old 03-01-2019, 07:34 PM
Dookay's Avatar
Disable it by pulling towards your for 30 seconds. Youíll see a confirmation on the dash when done correctly.
2019 Accord 2.0T/10AT
Platinum White/Black
Llumar CTX 15 Tint and Platinum PPF
JL Audio FIX86
Kicker KEY180.4
Kicker KXA400.1
Rockford Fosgate 12" P2
OEM Auto Dimming Rearview Mirror w/Homelink
Dookay is online now
post #5 of 20 Old 03-02-2019, 03:18 AM
Triangle wins
jrjmurray's Avatar
Originally Posted by Dookay View Post
Disable it by pulling towards your for 30 seconds. You’ll see a confirmation on the dash when done correctly.
Not even 30sec...just momentary on mine and it toggles auto brights on/off as the dash “A)” symbol shows.
This is actually a minor annoyance as it happens every time I flash someone (e.g. to let them go first at an all-way stop intersection)
jrjmurray is offline
post #6 of 20 Old 03-02-2019, 04:44 AM
Page 199:
Disabling or re-enabling the system when the
vehicle is parked with the power mode is in
ON and the light switch is in the AUTO
position.
Disabling the system: Pull the light switch
lever towards you and hold it for 40 seconds.
The indicator blinks twice.
Re-enabling the system: Pull the light
switch lever towards you and hold it for 30
seconds. The indicator blinks once.
napkins likes this.
tmorriso is online now
post #7 of 20 Old 03-02-2019, 05:03 AM
Triangle wins
jrjmurray's Avatar
Originally Posted by tmorriso View Post
Page 199:
position.
I guess, but I can toggle mine anytime while I am driving and the lights are on with just a quick flash of the brights. Can anyone else confirm?
post #8 of 20 Old 03-02-2019, 06:26 AM
Dookay's Avatar
Itís permanent until you hold it again for 30 seconds. I believe with your method, itíll reset back to auto after the car shuts off.
JL Audio FIX86
Kicker KEY180.4
Kicker KXA400.1
post #9 of 20 Old 03-02-2019, 09:29 PM
RB16P
Agreed. I activate and deactivate this feature while driving for hours at night. I keep thinking I pull it towards me twice or away twice to activate but you maybe right jrjmurray it may be just a simple toggle.... I can't remember and I won't be back on land for a few weeks to try lol
rb16p is online now
post #10 of 20 Old 03-03-2019, 05:44 AM
The OP asked how to do this: "...never turn on the high beams unless I hit the high beam control lever"
Not "How do I turn the high beams off when the auto-headlights turns them on?"
post #11 of 20 Old 03-03-2019, 06:56 AM
Keyboard's Avatar
Agreed. The OP wanted to disable the automatic high beam feature and return to manual only mode for the high beams. However, he still wants the low beams to automatically come on. Your reply (post #6) above gave the right solution.
2018 Accord 4-Door 2.0T Touring [Modern Steel Metallic - 10th gen]
2011 Ridgeline RTL w/NAV [Mocha Metallic - 1st gen]
Previous Honda's:
  • 2014 Accord 4-Door V6 Touring [Crystal Black Pearl - 9th gen] (Traded)
  • 2010 Accord 4-Door EX-L V6/NAV [Bold Beige - 8th gen] (Sold)
  • 2002 Accord 4-Door EX-V6 [Noble Green - 6th gen] (Sold)
  • 1992 Accord 4-Door EX [Granada Black] - 4th gen] (Sold)
  • 1984 Accord 4-Door LX [Graphite Gray - 2nd gen] (Traded)
Keyboard is online now
post #12 of 20 Old 03-08-2019, 05:23 PM
Ion
Ion's Avatar
I like the auto high beams, but would like them to turn on less often. There's a setting for this in the user options with 2 options for sensitivity: "LOW" or "MIN". What is the result of choosing either setting?
2019 Accord Touring Hybrid
Ion is online now
post #13 of 20 Old 03-08-2019, 09:26 PM
Dookay's Avatar
There is? Where at?
JL Audio FIX86
Kicker KEY180.4
Kicker KXA400.1
post #14 of 20 Old 03-14-2019, 06:41 PM
Ion
Ion's Avatar
There is? Where at?
The automatic high beam adjustments are in "Settings" > "Vehicle" > "Lighting". I have the Navigation type display.
There's more settings in the headlight sensor adjustment than I thought. There's Minimum, Low, Medium, High, Maximum. Default was Low (sensitivity). I put mine on High and it seems to make the high beams come on less frequently and shut off quicker. I like it better like that.
Ion is online now
post #15 of 20 Old 03-14-2019, 10:09 PM
my automatic high beams sometimes dis-engage by itself.
I re-engaged it by moving the light lever forward a few times and back towards me a few times.
I'm not sure what is causing it to dis-engage. I actually like the auto high beams and want it on auto mode , but it's it's going to be a headache then I mind as well shut it off.
Accorde2018 is offline
possible to install LED Headlights (high & low beams)? Richee75 Audio, Electronics & Lighting 6 12-18-2014 08:10 AM
Big Wheels Wheels Keep on Turning. ksills Wheels & Tires 4 09-28-2008 03:51 PM
2006 brown/burned DRL/high beams madamd The 7th Generation 14 04-25-2006 05:50 AM
high beams Dave General Drive 4 05-12-2004 02:44 PM
