Can a 10 band DSP fix the audio? - Drive Accord Honda Forums
post #1 of 6 Old 04-12-2019, 09:52 AM Thread Starter
So I'm giving up on the AXXESS DSP, it's just garbage..
I've been looking at the Dayton audio 10 band DSP, has anyone used a 10 band on the stock deck?
I had to make very drastic adjustments on the AXXESS to get a flat EQ measurement on my RTA, so I'm worried 10 band might not be enough.
Sent from my BLA-A09 using Tapatalk
turner850 is offline
post #2 of 6 Old 04-14-2019, 04:58 PM
Which model/head unit do you have? I thought the output was rather flat just had factory crossover points. I will be starting soon my attempt on a sport 2.0(with the 8 speaker setup), I plan on using Audiocontrol D-4.800 amp with the built in DSP. Hopefully I can get a good reading on a RTA of the front & rear speaker output frequency response, I don't think it's been shared in detail on this forum.
jrvtecaccord is online now
post #3 of 6 Old 04-14-2019, 08:09 PM Thread Starter
I'm using the stock head unit, I have the AXXESS t harness sending the head unit signal to the axxess DSP, then from the DSP to a Rockford fosgate 400 watt 4-channel amplifier
from the amplifier I am spliced back into the t harness to the factory speaker wiring.
With four jl audio c2-650 speakers I had to make the following adjustments to get a flat EQ, using a Dayton audio RTA and true RTA on my laptop.
So this is what my RTA sees without any adjustment to the DSP (just using AudioTools for this post), as you can see the highs are WAY too intense, melts my ears
So after a little bit of tuning with the crappy AXXESS app, seriously it sometimes doesnt even adjust unless you move the sliders a second time. But this is with the adjustment shown on the first images
Also, if anyone is interested in adding a DSP or amp. There is PLENTY of room under the cup holders for the Rockford Fosgate T400X4AD + a small DSP
post #4 of 6 Old 04-15-2019, 12:48 PM
That is some crazy adjustments you had to make just to make it somewhat flat! Have you tried just measuring the speaker out to a RTA(to take the speakers, reflections, etc. out of the equation)?
post #5 of 6 Old 04-15-2019, 01:01 PM Thread Starter
Humm, I haven't. I'm in no way an audio pro, just following YouTube videos and spending way too much money.
I have a Dayton Audio DSP coming this week I'm going to try it out.
post #6 of 6 Old Today, 12:52 PM
The front is heavily EQ'd to compensate for missing information between 3kHz to 10kHz hence you get all the harshness when you swap speaker. Stock non-premium tweeter uses 6dB/octave and no crossover on woofer. The rear is flat but rolls off earlier and with lower output.
I am targeting the system by bringing rear to the front and left front speaker to center. Fade all the way to rear and it sounds completely different than front output. DSP also should worker easier if only frequency input below 80 needs to be corrected then any other EQ are used for correcting other frequencies.
Sent from my SM-G950U using Tapatalk
82801BA is online now
Any Chicago (Band) Fans Here? Coach Steve The Pit 9 01-19-2018 02:52 PM
Navigation Screen "Brownish Band" w/Polarized Sunglasses TEK Rider The 9th Generation 14 09-13-2016 02:17 PM
Upgrade audio? Dsp flat? [email protected] Audio, Electronics & Lighting 9 07-28-2016 10:34 AM
FS: Cobra Radar 15 Band and Aluminum Lugs 07AccordLX DriveAccord Classifieds 3 09-08-2014 08:41 PM
I4 Power band zman0125 The 8th Generation 9 09-18-2011 12:25 PM
