Safe to use sitting oil? - Drive Accord Honda Forums
post #1 of 16 Old 04-04-2019, 01:41 PM Thread Starter
Hi everyone,
I purchased some 0w20 synthetic oil in the fall when it went on sale. Now it's been sitting in the trunk of my car in the (not heated) garage all winter, so I'm curious, would it still be okay to use, or did I simply throw money away?
Blank Point is offline
post #2 of 16 Old 04-04-2019, 01:49 PM
Originally Posted by Blank Point View Post
Hi everyone,
I would probably throw it away if I were you and get some quality used oil from a dealership, oil change shop, etc. they usually sell it cheaper than new and you know for a fact it has to be good or it wouldn’t have already been used. New oil that has been sitting around is probably the worse thing for your engine.
cookieman214 and qman like this.
x2aws is offline
The Following User Says Thank You to x2aws For This Useful Post:
cookieman214 (04-05-2019)
post #3 of 16 Old 04-04-2019, 01:58 PM
2006 Accord EX
2Accordz's Avatar
It's good, no worries.
think of it this way:
It routinely sits on the shelf at the parts store...in the same condition(sealed) and, it's made to withstand hot and cold temps...that's its job...without any loss of viscosity.
It's perfectly fine.
2006 Accord EX 2.4L Coupe...187k and counting..
2Accordz is offline
post #4 of 16 Old 04-04-2019, 02:01 PM
AlanTheBeastV2's Avatar
It's fine.
2003 Accord 2.4 LX Sedan.
AlanTheBeastV2 is offline
post #5 of 16 Old 04-04-2019, 02:01 PM
Totally fine. It’s oil, not milk.
paterico is offline
post #6 of 16 Old 04-04-2019, 02:10 PM
emeron's Avatar
Sitting for a few months? No worries.
Now if it was sitting under the sun in a dark colored container in Arizona all summer, that would have made me think, but winter cold? Absolutely no worries at all. Motor oil does not freeze; it is designed to not to do that. Not at temperatures naturally encountered on this planet.
2014 Accord Coupe cvt ex-l nav
2004 CR-V mt
emeron is offline
post #7 of 16 Old 04-04-2019, 02:43 PM
@emeron : even then, nothing compared to the heat, friction and chemical environment of a running engine.
post #8 of 16 Old 04-04-2019, 02:53 PM
emeron's Avatar
Agreed. Motor oil degrades quicker in higher temps. That's why mileage is not a fully relevant measure to determine oil life. Hours, temperature and RPM are some of the factors that come to mind.
2004 CR-V mt
emeron is offline
post #9 of 16 Old 04-04-2019, 07:16 PM
VFR4Lee's Avatar
Use it.
2008 Coupe V6
VFR4Lee is offline
post #10 of 16 Old 04-04-2019, 07:29 PM
Hudouc's Avatar
It's fine.
However, this does make my wonder. If the oil sit long enough (for years), won't the plastic bottle that it sits in degrade and leave the oil less than desirable? Or I suppose which will expire first? The oil or the bottle?
2010 Accord LX Sedan (125k)
Crosstour Gauge Cluster
Thule Aeroblade Roof Rack
Firestone Firehawk Indy 500 + 2017 Hyundai SantaFe Sport Wheels
K&N Drop-in Filter
TL Non-SH-AWD RSB
OEM EX trim front shock tower brace
Koni FSD
Eibach Pro Kit Springs
RV6 Stuff
Ktuner
Coming soon:
OE deck lid spoiler
2018 Camry SE
Stock & will stay that way.
Hudouc is online now
post #11 of 16 Old 04-05-2019, 04:37 AM
I doubt the plastic would decay except in the case of being in direct sunlight.
post #12 of 16 Old 04-05-2019, 05:17 AM
Shake it just prior to pouring it in. Some additives could have settled to the bottom of the container(s). Good to go.
post #13 of 16 Old 04-09-2019, 11:59 AM Thread Starter
Thanks for the responses everyone.
So I changed the oil yesterday after work with the oil and filter I had sitting around. Once I had it all changed I looked in the jug and saw a bunch of translucent flakes floating near the bottom in the last half liter I didn't use, pictured below.
In case anyone is wondering, it's pennzoil ultra platinum 0w20
So now I'm curious as to how much of this is floating around in my engine. At this point I'm debating changing it again.
Click image for larger version
post #14 of 16 Old 04-09-2019, 12:03 PM
sandevino's Avatar
Send a message via AIM to sandevino
That’s why you have a filter.
In all fairness, that oil has been sitting around far longer on truck trailers, shipping containers, delivery trucks and in boxes at the store than in your trunk. Check it again in 6,000 miles when you change it...
2017 V6 Coupe 6MT
Still Nght Pearl
CDV-less
sandevino is offline
post #15 of 16 Old 04-15-2019, 01:30 PM
2006 Accord EX
2Accordz's Avatar
Did you even see the post above yours, telling you to shake it up a bit??
Oil has additives in it.
When you only use a little bit of oil that's been sitting around, the additives settle to the bottom. Normally you're dumping oil in upside down which empties everything into the engine, additives et al.
Again, you'll be fine. I would not worry about it.
The other 4 quarts will have enough in them.
2Accordz is offline
is it safe to use hand sanitizer on paint ? blkcoupe808 Maintenance & Detailing 12 10-05-2015 11:23 AM
Safe to use Nokya Arctic White for High Beams? Slade Audio, Electronics & Lighting 11 12-09-2012 02:22 AM
Is it safe to use Aftermarket brakes? Bandigo The 8th Generation 19 04-12-2011 03:27 PM
Is it safe to use "scrub" sponges on the exterior? Contriver2 Maintenance & Detailing 15 01-13-2008 09:32 AM
Are safe deposit boxes safe from Homeland Security? rookie The Pit 22 02-16-2006 07:09 PM
