car shaking cel light blinking - Drive Accord Honda Forums
post #1 of 19 Old 04-07-2019, 03:18 PM Thread Starter
car shaking after timing belt change, bringing it back to the mechanic , didnt get any codes ran , before i was getting a p306 misfire code ,
check engine light is on and is blinking and the engine is shaking a little... . any comments? or experiences with this ?
car: 09 accord coupe ex-l v6 blue belize pearl
8000k fogs and headlights, suade headliner, remote start, alarm , pioneer touchscreen 2300 , accord sport rims, wrapped hood, mirrors , interior
ninjaseal is offline
post #2 of 19 Old 04-07-2019, 03:28 PM
What?
RickBlaine is offline
post #3 of 19 Old 04-07-2019, 03:32 PM
Elvira - the car
Miker's Avatar
Sounds like the mechanic that put your timing belt on didn't put it on correctly and the "timing" of the spark is off causing the blinking CEL (misfires)
Mike
2013 EX-L V6/6A (no nav) sedan CBP
"vita est brevis, vado pro V6" - Me
"Speak only when you feel that your words are better than your silence." - Anonymous
"Either write something worth reading, or do something worth writing."- Benjamin Franklin
"Never walk past a mistake " - Colin Powell, retired four-star General
Miker is offline
post #4 of 19 Old 04-07-2019, 03:53 PM Thread Starter
oh great, now what
post #5 of 19 Old 04-07-2019, 03:54 PM Thread Starter
whats the fix for this?
post #6 of 19 Old 04-07-2019, 05:26 PM
The fix is to do the job again, but have someone that knows what they're doing do it.
If it was mine, I would not drive the car to the shop, I'd have it towed. Why risk damage to the engine if you don't have to?
Hudouc and enne like this.
20AccordEXL11 is offline
post #7 of 19 Old 04-08-2019, 01:13 PM Thread Starter
ok the problem was it needs new spark plugs and coil packs at cylinder 3 and 6 , hes going to change the rest next time i go , blinking cel is gone , car sounds good at idle and rides smooth again
The Following User Says Thank You to ninjaseal For This Useful Post:
Miker (04-08-2019)
post #8 of 19 Old 04-08-2019, 03:32 PM
Elvira - the car
Miker's Avatar
Whew!!
Mike
Miker is offline
post #9 of 19 Old 04-10-2019, 02:43 PM Thread Starter
lights back on for a misfire at cylinder 6 , i just had the spark plug and coil pack changed , lights still on ... now what? can anyone help? im bringing it back to the mechanic next week
is it time for a new car at 146k? problem after problem......
post #10 of 19 Old 04-13-2019, 02:00 AM Thread Starter
anyone out there?
post #11 of 19 Old 04-13-2019, 07:01 AM Thread Starter
ok i return with good news , i got a full tank of shell gas from the station i normally use (the time before this i used a different shell station and got engine misfires and a blinking cel and then replaced the coil packs and sparks in cylinder 3 and 6) ;moreover, i filled her up with the shell i normally use and the check engine light shut off and now she idles smooth like before... wow what a relief , lets see how long this lasts
146k
post #12 of 19 Old 04-13-2019, 08:32 AM
That is good news. I always try to get gas at the same station if possible.
Was the light 'off' immediately or did it take some driving before it shut off?
I got a CEL and mis-fire on #3 code a while back on mine. Changed the plugs and left the code showing but haven't driven it far, so I think the code will still be there.
post #13 of 19 Old 04-13-2019, 08:56 AM Thread Starter
i drove 118 miles with new spark plugs and coil packs , i was down on empty and refilled , when i turned the car back on the light dissappeared and then she started running smooth again,
my plugs had a bit of oil on them i believe , i never changed them at 146k miles (im a moron i know this already)
post #14 of 19 Old 04-13-2019, 09:00 AM Thread Starter
my mechanic told me to change the other 4 (changed 3 and 6 already)
post #15 of 19 Old 04-13-2019, 12:40 PM
8th Gen Believer
I have the same car, 135k miles, had the misfire code P0303, the#3 plug was fouled. If it were me I'd do what your tech said and change them all and coil packs.
________________
2009 EXL V6 Sedan
Royal Blue
25% tint
OEM fogs / 22mm Progress RSB / Ultra Racing solid FSB / Koni FSDs / Modulo grille / debadged trunk /
Previous cars: 2003 EXL V6 Accord Coupe
1995 Accord EX Sedan
1985 Mercedes 300 Turbodiesel
1989 Volvo S90 Turbo
slimm1469 is offline
Slight Shaking at High Speeds, No Shaking at Higher Speeds CDsDontBurn Problems & Solutions 4 12-18-2018 02:34 PM
2017 Sport with CEL and blinking D light Chet91 The 9th Generation 7 04-26-2018 02:18 PM
Blinking CEL at WOT BullShifter The 7th Generation 12 10-27-2010 03:41 PM
Blinking CEL HondaFamilyMan The 7th Generation 0 12-04-2008 04:04 AM
Occasional blinking CEL under hard acceleration ('04 V6) mrogers Problems & Solutions 7 08-06-2008 03:48 PM
