2014 4 cyl... Won't move - Drive Accord Honda Forums
 3Likes
post #1 of 43 Old 05-12-2019, 03:07 PM Thread Starter
That's about it...won't go. Permanently in neutral. Got to the main Street, stopped, waited...went to go and heard/felt a pop/clunk...then some whining like gears grinding... No motion. Nothing. Car can be pushed around in park ,as if it's in neutral.
FML.
Can't imagine the CVT is shot....I think. 132,000 on it, drain and fill at.40k,80k and 3x at 120k....
If I put it in drive, I hear a light rotating/grinding sound but no motion....and if I go to park it makes a more pronounced grinding sound. I can shift to neutral and let it settle and the go to park with no noise.
I see nothing hanging down or any fluids
Justanotherguy is online now
post #2 of 43 Old 05-12-2019, 03:09 PM
AccordMoto's Avatar
Check and see if a CV shaft is snapped. Turn your wheel all the way to the left to check the driver, all the way to the right to check the passenger.
Also do the check with the car in drive with the emergency brake on, and see if you can see or hear anything.
'03 Accord LX 4cyl
'15 Accord Coupe EX-L V6 MSM
AccordMoto is offline
post #3 of 43 Old 05-12-2019, 03:34 PM Thread Starter
How expensive is this? And does only one drive it
What would dealer cost???
Click image for larger version
post #4 of 43 Old 05-12-2019, 03:41 PM
AccordMoto's Avatar
It depends on where you go and what parts you buy. But. Im gonna say ~$300. (Im not sure though as I do all repairs myself).
A CV axle is around $100 and labor depends on the shop. Any shop can do it. I absolutely DO NOT reccomend the dealer. Find a good independent mechanic nearby.
And to answer your question, no you cannot drive with only one. The nature of the differential will not allow the car to drive.
Justanotherguy likes this.
'03 Accord LX 4cyl
post #5 of 43 Old 05-12-2019, 03:44 PM
PaSt's Avatar
If you're in the city, i would recommend bringing it to HAAS on Montose, otherwise you might be under the mercy of your local Honda dealership, them are pretty easy to R&R.
good thing it wasn't the trans. Honda CVT Belts are supposedly steel
PaSt is offline
post #6 of 43 Old 05-12-2019, 03:46 PM
If you buy the part and have a shop replace it, it's usually cheaper. If you don't want to deal with buying the parts and would rather a shop do all the work, research well. Go to a local shop and avoid the dealer if you don't want to be ripped off.
2018 Mazda 3 Hatchback Touring AT
2005 Honda Accord V6 - 185k - Sold
salcuta is online now
post #7 of 43 Old 05-12-2019, 03:46 PM Thread Starter
Tow is pulling up ..I still have a choice
post #8 of 43 Old 05-12-2019, 03:48 PM
$700-1000 based on what others paid. OEM axle is 500 alone.
post #9 of 43 Old 05-12-2019, 03:49 PM Thread Starter
Ok thanks so much!
post #10 of 43 Old 05-12-2019, 03:51 PM
AccordMoto's Avatar
Originally Posted by salcuta View Post
$700-1000 based on what others paid. Oem axle is 500 alone.
(the dung of a bovine)
'03 Accord LX 4cyl
Last edited by RickBlaine; 05-13-2019 at 05:49 AM. Reason: Swearing on Drive Accord!
post #11 of 43 Old 05-12-2019, 04:06 PM
Honda Enthusiast
da35's Avatar
OEM axles are ~$155: https://www.hondaautomotiveparts.com...-half-shaft-l4
Your Honda dealer will install Honda parts sourced outside that dealer.
DARKART
CR2 Sport
Crystal Black Pearl
K24W1 Earth Dreams/6MT
If it's Mugen, it's worth it.
_____________________________________
1990 ED6 Civic DX HB Frost White
2006 R53 MINI Cooper Sa Dark Silver
da35 is offline
post #12 of 43 Old 05-12-2019, 04:11 PM Thread Starter
Dropped at.local repair shop....he thinks honda dealer has a gate at the street..no. Drop zone
post #13 of 43 Old 05-12-2019, 04:37 PM
Found it cheaper? Great! However, taking it to your local dealer doesn't garuantee you that price. I've seen dealers charge 500 for the part alone.
post #14 of 43 Old 05-12-2019, 04:42 PM
AccordMoto's Avatar
I agree, but I found it cheaper, and so did others. Anybody can order CV axles all day for ~$150. Dealers are a rip off and don't offer any better service than a competent tech at an independent shop. I would not go to a dealer for anything other than recall and warranty work.
'03 Accord LX 4cyl
post #15 of 43 Old 05-12-2019, 04:52 PM
Correct. That is why I suggested by the part online or take it to a non-dealer shop. Go back and read my first reply.
pass. side mirror won't move fully left to right ? blkcoupe808 The 7th Generation 5 04-01-2016 06:20 AM
4 cyl. verses 6 cyl.? looking to buy one bvshearz The 7th Generation 68 03-06-2011 08:40 AM
1999 EX(4 cyl) misfire on #1,#2,#4 cyl. nm747 Problems & Solutions 17 09-20-2010 02:02 PM
Need Advice: 4-cyl vs 6-cyl dragonle87 The 7th Generation 48 09-13-2010 09:19 PM
'08 EX-L 4 cyl Manual vs 6 cyl...One Last Sanity Check??? Tom R The 8th Generation 27 12-20-2007 10:48 AM
