1 - 2 of 2 Posts
I am having trouble removing the instrument cluster on my 02 accord v6. I have lowered the steering wheel, I have removed the front bezel and removed the 4 screws on the cluster.
I can move the panel around, but the cable on the left side looks like it is behind another cable. i don't want to pull the the cluster through and damage the connector or pins on the left side.
I guess I could use a flat head screwdriver to push up on the cable that is in the way, or use a flat head to push on the connector key and remove the connector.
does anyone have any suggestions for getting the cluster out of the dash?
The cluster should only have 3 cables / 3 wire harnesses going to it. I don't remember there being any additional cables going to or from the cluster. When I removed my cluster, it was just doing what you said and having the cluster "fold up" before pulling out to remove the cluster from where it sits.
1 - 2 of 2 Posts
