http://autos.yahoo.com/maintain/repairqa/fluids_heat_air_conditioning/ques021_2.html
Fan Operation
At highway speeds, there is usually enough airflow through the radiator that a fan isn't needed. So the fan usually only operates when the vehicle is sitting in traffic or driving at slower speeds.
On older applications, the electric fan is controlled by a temperature switch located in the radiator or engine. When the temperature of the coolant exceeds the switch's rating (typically 195 to 235 degrees F), the switch closes and energizes a relay that supplies voltage to run the fan. The fan then continues to run until the coolant temperature drops back below the opening point of the switch. Most electric fans are also wired to come on when the A/C is on. Many vehicles also have a separate fan for the A/C condenser (dual fan systems). One or both fans come on when the A/C is on.
In newer vehicles with computerized engine controls, fan operation is regulated by the engine control module. Input from the coolant sensor, and in many cases the vehicle speed sensor too, is used to determine when the fan needs to be on.
CAUTION: Many electric fans are wired to come on anytime the engine is above a certain temperature, regardless of whether the engine is running or not. This means the fan may come on after the engine has been shut off. So keep your fingers away from the fan at all times unless the battery or fan motor wires have been disconnected.
Aftermarket adjustable fan switches. You tell it how hot.
http://www.etrailer.com/dept-pg-Radiator_Fans.aspx
