1 - 2 of 2 Posts
130k miles on car, running perfect.
Suddenly codes are:
P0507
P2279
I am having the IACV replaced by a local shop (I don't have time).
They are recommending a "Fuel System Cleanse" also. I have new filters, plugs, 02 sensors on the car 10k miles ago.
Is a fuel system cleanse really necessary?
Thanks
Based on the codes that you provided you have an air intake leak, you should double check on that. Make sure everything is sealed properly. that may cause your car to run a little rough. and that's why is throwing those codes.
A fuel system clean always helps but that is not the problem with your car, so don't expect the codes to disappear once you do that.
1 - 2 of 2 Posts
