1 - 2 of 2 Posts
Hello all. Thanks for looking at this
I have an 04 accord which will periodically just not start. No sounds, no clicks. The starter simply won't fire. Video here:
Doing some research, could this be some kind sensor error that isn't working correctly.
It has eventually turned on, after some time and jingling. It is happening with increasing frequency and duration.
The starter, battery, and key are all new (< 6months old)
Any thoughts? The Honda dealer wanted to run a 150$ diagnostic just to identify the problem, so I am hoping to not have to turn to that
Thank you got your attention and consideration!
Here are my guesses.
1. Bad neutral safety switch
2. Bad ignition switch
3. Loose connection at the starter.
4. Bad starter.
Have you tried moving the gearshift to neutral and start the car, or slide the transmission lever from park all the way down and back to park? Either power is not getting to the starter OR the starter is bad. I suspect power not getting to the starter.
1 - 2 of 2 Posts
