1 - 6 of 6 Posts
This only happens once the car warms up.
While driving everything feels fine. When I come to a stop the car bucks/stutters continuously.
This immediately stops when I put it into N or P
This also immediately stops once I press the gas
Are these symptoms of bad CKP sensor? I can only afford to fix one more thing as I am buying all the tools required with each repair I do. Or do you think there is a more likely culprit I should look into based off the symptoms?
ODBII code P0341...replaced CMP (A), did nothing
Here is the manual on how to repair this
www.autocodes.com/uploads/honda/honda-p0341.pdf
Of you have replaced the sensor, check the wiring as well. You need to also check the timing marks and be sure they line up. That is all in the troubleshooting doc.
Discussion Starter #4
This seems way more involved than the Haynes manual I have. Haynes just has me unbolting the sensor and bolting a new one back in. Is this much disassembly necessary?
I asked if you ever ran the engine low on oil because if you did and the chain stretched, it would cause the engine to get out of time which sometimes manifests as a CKP sensor error.
1 - 6 of 6 Posts
