Hey Guys,
Newbie here. Hopefully someone can Help. I somehow stripped the threads of the upper rear drivers side brake caliper Bolt. I purchased a duralast kit from Autozone and attempted to use the new bolt with the kit, and somehow stripped the threads. It wont lock and just keeps spinning. I have tried to remove it, however, when I do it just spins as well and the pin and boot also spin. I tried using a wrench to stabilize the pin but the bolt just continunes to spin and wont back out. Ive tried slipping a screw driver behind the bolt head and no luck. Tried pliers/grips etc to add some pulling tension as I turned and still no luck. I was thinking about cutting the bolt/pin and trying to get it out that way and then just replace both with the autozone kit.. Any thoughts, ideas, info, advice is definetly appreciated...
