I have an 05 accord. 2.4 manual transmission. After a couple days the battery dies. Battery is fairly new. Alternator is charging. I hooked up a meter and I'm getting a 0.13 amp draw. I pulled all fuses and relays and the only fuse that makes any difference is the main battery fuse. I pulled the fuse box under the hood and started pulling plugs. The plug with two large white wires one with a blue stripe stopped the draw. I tried unplugging the ignition switch. No change. What else could be feeding power from these two large white wires.
