So I had a remote starter installed on my car and shortly after had issues with my master window switch not working. I replace the switch with no luck then I checked the sub wiring of the door harness which goes to fusebox it seemed it was really dirty and sure enough a wire was pulled out. so I replaced that as well with a original part from honda. About a week about replacing the part (which worked) I experience no keyless entry, no turn signals. headlights turn on but wont show on the cluster, and no high beams(also doesn't show on cluster). However get this, when I open the driver door everything works, and if I close it it stops working. Also, after some guess and checking if I take out one of the plugs of the subiwiring I replaced from the fusebox windows r offline but all the electrical I mentioned above start working. Ive checked fuses and they are okay now I am leaning towards possibly a bad multiplex?? anybody with knowledge please help!!!!!!!
