Just copying the 04 thread @princess started here: http://www.driveaccord.net/forums/2...ions/4565-parking-brake-check-adjustment.html
(I searched but couldn't find such a thread until I went outside the site and searched. Read that thread!)
In my case I only removed the console's rear access panel (two side screws, then pull it out). The socket extension winds up being positioned down at at the carpeted hump, but good luck to you if you can actually get your head down there to look at the bolt.
I just sat on the back seat and felt around while holding the socket extension and *mostly* made contact with the bolt, just enough to tighten it. You'll know you're poking it close when the brake handle moves ...
Removing the console would make adjustment far easier, assuming you don't mind removing the center console.
