how about a single din radio ???
l can cut the piece highlighted in red or right under it
do i have to keep the factory radio [the rear part] in order to use the climate controls?
woluld i still need to do any pcb board modifications ??. i need to find out if i can relocate the pcb board
i really want a in dash screen but im not willing to pay $200 for a metra kit :frown
A few thoughts:
1: Basic Single zone Air con is simple to program for aftermarket designers. Dual full HVAC control is NOT!
2: Every aftermarket unit that has CLAIMED to correctly implement Full Dual Zone Climate control has failed to correctly implement Hondas HVAC logic.
3: The metra kit includes a simple single zone Air Con controller, however you say you don't want to use the metra kit, I can understand that BUT how do you plan on mounting a double din aftermarket unit once you remove the OEM Radio/CD/Air unit? and you still need to find a way to control the single zone Air once the OEM Radio/Air Con unit is removed.
The buttons you circled are connected to nothing.
FYI Here are a few pictures of the Radio unit dissembled, click on them to zoom in ->
/Honda/HvacPictures.html
This gives you an idea of the size of the HVAC/Radio board and what is involved in using it - note this is a Dual zone Full HVAC control unit ->
/Honda/HvacRelocate2.html
It's a big job with a full HVAC unit, the metra kit is the easy way to go if you only have a simple single zone Aircon unit.
As
jimijam said, either give it up and go the lower cubby - or try the metra unit. Unless you are good with electronics, soldering and like fabricating a new dash insert from scratch and have a lot of time on your hands, there are not many other satisfactory options.
