That is right. You can do the math for proof. According to
https://automobiles.honda.com/accord-sedan#, the gear ratio for 10th gear is .517 on a 3.55 final drive. That means in 10th gear, the engine spins 1.835 times every time the wheel spins one time.
The tires are 235/40-19s. That gives them a diameter of 26.40” and a circumference of 82.93” or 6.91 feet. One mile is exactly 5,280 feet. For that tire to travel 5,280 feet, it must spin exactly 764 times. One mile per minute is 60 miles per hour, which is almost 100 km/hr. That means to travel at 60 mph the wheel must spin at 764 rpm. We know that the engine must spin 1.835 times for each rotation of the wheel. Therefore at 60 mph, or 764 rpm for the tire, the engine must spin at 1,402 rpm. At 62.5 mph it should be 1,460 rpm. That’s pretty close to the 1,500 rpm you saw on the tach. And if you have 17" wheels, those smaller 225/50-17 tires (25.86" diameter) would explain the very slight difference.
So yes, the 10AT cranks about 1,500 rpm at 60 mph. The CVT can theoretically go lower if it locks into its top ratio. The CVT's ratio spread is 2.645 to .405 on a
3.28 final drive. If you trust Honda's information and do the math, it should crank about 1,014 rpm at 60 mph. But something tells me the CVT never locks into that max ratio.
