My 2008 is quickly closing in on 100k. It's been a reliable car and I want to keep it that way. Is there a 100k service that I could have done ? What would be the important things to get taken care of.
Depends if you have a 4 cyl or 6 cyl....the 6 needs a timing belt and water pump, 4 does not. They will both need a 100k tune-up. If you have an automatic you should flush the trans. I'm not sure of when the radiator fluid needs to be changed?
Spark plugs for sure. I guess it depends on how you've taken care of your car and the service it has seen along the way. If its been over 3 years, do a brake flush. Coolant if you haven't done it. Maybe a new cabin and engine filter, and just for good measure, check your belts and hoses for cracks and wear. Transmission/diff flushes if you havent done one in maybe 30-50k miles depending on the kind of driving you do.
