1 - 9 of 9 Posts
Whatsup I want to put the reflectors that come with the 11-12 accord onto my 08 accord I kno they don't reflect and alot of people don't like em but I do. Does anyone have a part number or how I can go about doing this.
Anyone?
if you need black i have my old garnish
you'll need the 11-12 garnish as well as the reflectors. Honda dealer is where its at...
The OP needs the USDM 11-12 trunk, not JDM inspire trunk lid with reflectors.
I have polished metal
I don't want the inspire light I want the oem garnish reflector
You would need the 11-12 trunk lid that has slot for the reflectors, then you also need to drill couple screw holes to affix the reflectors on your 08. The entire conversion will run you slightly over $300 if you get them all brand new.
You need
18
22
23
24
25
31
Link to part numbers.
the 08-10 and 11-12 garnishes are completely interchangeable without modification. they use the same mounting points so if op finds one intact with the reflectors that will be all he needs.
The trunks for 08-10 and 11-12 are identical in exterior but different in the metal frame, they came in different part numbers too.
OP can swap the 11-12 garnish, but he needs to drill new holes and slot on his 08 trunk to affix the 11-12 garnish with reflectors. Pretty much like 08-10 doing inspire trunk conversion.
08-10: 68610-TA5-A00ZZ
11-12: 68500-TA5-A90ZZ
1 - 9 of 9 Posts
