1 - 8 of 8 Posts
I have found some local winter tires 205/65/15 on OEM steel wheels.
Will that fit my 06 V6 (5at)?
Thanks
Since the I4s came with OEM 15" Steel wheels and they have the same suspension/brakes as your V6 AT, they should fit fine.
mobiless2
Yes, since I-4 & V-6 Sedan share same front rotors 11.1".
Discussion Starter #4
V6 and I-4 have different suspension (springs/struts), but I think you are right, the brakes are the same
Discussion Starter #5
Thanks for that... The rears wouldn't be different at all right? I wouldn't have bigger brakes if the car that the steel wheels came off of had drums right?
Thanks again
mobiless2
No rears are 10" drums & rotors, your good. Only real difference on suspension would be higher rated springs for weight and valving for shocks, side by side they are identical.
Discussion Starter #7
Thanks a lot for the info!
only the 6mt get larger front brake discs
1 - 8 of 8 Posts
