1 - 5 of 5 Posts
I have a 94 Accord EX with almost 225K miles on it. I forgot to change out my spark plugs at the 200K (they were changed at 100K), and now one of them appears to be stuck. I'm trying to figure out whether I should have a mechanic attempt to remove the stuck plug, or should I just replace the plugs that came out easily and worry about the last plug later. If I have a mechanic attempt to remove the plug, what are the risks if the plug breaks? Thanks in advance for any advice.
Honda Enthusiast
2017 CR2 Sport 6MT CBP
Try PB Blaster then work the plug back and forth until it comes out. Patience is key.
A 50/50 mix of acetone and ATF works wonders on stuck threads. Especially steel threads into aluminum.
Runnin' in the 90s
Also try torquing it GENTLY to the right a little, then try torquing to the left like normal. The back and forth motion can help break them free.
1 - 5 of 5 Posts
