1 - 3 of 3 Posts
My doors simply do not want to lock, the power lock works fine except on the driver-side door, but neither door will lock from the outside with my key, the driver-side will lock from the inside ONLY when the door is closed.
Honda Enthusiast
2017 CR2 Sport 6MT CBP
You need to pull the door panels and examine the insides. The keyhole should always work unless your key is HIGHLY worn. Has there been theft attempts in the past through the keyholes?
1 - 3 of 3 Posts
