hmmm clunking eh!? could be many things...
for one yah, it could be the suspension, although
it could also be your control arm/s or stabalizer bars if you are experiencing turning/driving problems, or either you could be having an issue with the the whole hub coming loose because the halfshaft could be coming loose and knocking behind the hub or maybe you have a massed up halfshaft or a damaged CV joint so maybe check the CV boots for any tares because water and debris damage can brake your CV joints and you would have to replace the whole halfshaft....just many different problems i think it could be...hope this helps some wat...
