1 - 6 of 6 Posts
1999 2.3 leaks when the engine is warm. This leak is where in the engine and transmission join at the front of the car (the crack). What are some options for a repair, or is this a common occurrence? Thanx for any help!
A leak from the radiator hose housing on the front of the engine or the temperature sensor in that same area would be a couple of possibilities. Coolant from one of those may be running down and showing up in the "crack".
Agreed....you should probably clean the area first THEN take a look where leak is coming from. It is most likely NOT coming from where the engine and transmission are joined together.
Coolant leak between trans and engine
1999 Accord LX 2.3 has a small leak when the car is running between the trans and engine. Coolant bubbles out where they join. What does this mean? It can't be good.
1 - 6 of 6 Posts
