1 - 3 of 3 Posts
Anyone have a step by step with photos on the process? Hidden well. Have changed 09 but this one is hidden. Let me know. Lan6289
2001 Accord EX change A/C filter
First remove small panel inside the compartment directly behind the shifter, it just pops out, and remove one screw on the right. Next remove fuse panel door on right side of glove box and remove two screws inside, they are holding the large panel below the glove box which can now be popped off. Then open glove box and remove two screws by latch. Next pop tabs and remove two screws one on each side of glove box. Next close glove box and remove 3 screws at base of glove box. Next remove 3 screws on metal brace below glove box. Next work glove box partially out and unplug lamp on left side of glove box. Next remove the glove box completely. Next move metal brace the A/C filter door is behind it. Pull up and out on A/C filter door. Remove 2 filters, vacuum or replace.
1 - 3 of 3 Posts
