I have owned this car for three years now, and I have fallen in love with it. It most recently started what I guess you would call "double engagement?"
I noticed last week when putting the car into drive my engine jerks, it has always slightly jerked which is normal, but it started doing a second more violent jerk. It only does this when I put the car into drive and only after at least 20 minutes of driving. It does not make any noises, and it doesn't ever happen upon the first 20 minutes of driving. I took it to the shop, where I was told the motor mounts needed replaced, but that did not fix the issue. I then asked to have my transmission tested. When I came back to check on my car, I was told that the transmission on this model does not include a pan and the filter is inside, so they could not thoroughly test it without charging $1,000 to take it apart. What they did tell me however, is that they found minimum metal on the plug when replacing 3 quarts of my fluid, but none at all in the fluid. I am curious as to if anyone has experienced this, and what the issue is. Is it for sure my transmission?
