3.5L intake manifold taken off a 2005 RL. Perfect fit for any 7th, 8th and 9th(?) gen 6MT Accords, and fits with minor modifications on 5AT Accords. Flows much better than the stock 3.0 manifold, and should be a bit better than the stock 3.5 manifolds.
The butterfly valve actuator is broken, so you'll have to swap that over from your stock 6MT manifold, or delete it if you have a 5AT. I also lost most of the hardware for this one, so you'll need to use the bolts from your stock manifold or buy new ones.
Cleaned and degreased, and briefly run on my car to verify no vacuum leaks. Local delivery/pickup, or pay for shipping.
