Magnesium intake manifold off of a 2005 Honda Accord Hybrid. Fits 7th, 8th and 9th(?) gen 6MT Accords, and 5AT Accords with a little modification. Much lighter, better flowing and more resistant to heat soak than the stock 3.0 and 3.5 manifolds. It does not include a vacuum line for the active engine mounts on the Accord, you'll have to tap vacuum from something else or just not connect it. If being used on a 5AT Accord, you will need to delete the butterfly valves.
However, this manifold has some flaws
1.) The center bolt on the manifold cover is snapped
2.) There is a large crack in the manifold internal wall (visible in image showing manifold inlet)
Both of these don't appear to cause any issues, I ran this manifold on my car for a year with no problems, and it didn't leak at all. However, it's something to watch out for.
I also lost the hardware for this one, so you will need to use the bolts from your stock manifold.
Local pickup/delivery, or pay for shipping.
