1 - 6 of 6 Posts
Are the metal ring type gaskets between the front pipe and manifolds reuseable? I am going to be replacing the front pipe soon.
Yes, but you should not do that as you might experience an exhaust leak. It is a copper crush type gasket and you should get new ones, they aren't that expensive. I went with aftermarket Mahle brand, they work just fine.
Same as any oil drain crush washer. You can reuse them as long as it works.
The crush washers either new or used ones will get “crushed” to the same thickness and it will not leak.
AutoZone sells the Mahle set for $9.99, for that cost go with new ones.
1 - 6 of 6 Posts
