1 - 3 of 3 Posts
EX (2.4 L, 5Speed Auto)
I can hear starter engaging the flywheel and turning (cranking, verfied on ODB meter that seeing RPM reading as it turns) ODB also reads MAP at 90 Kpa and MAF at .2 g/s.
I have checked the fuel pump, (I can feel the vibration from the motor as i checked from the trunk access area)
I pulled the spark plugs thinking if there is a flooding issue but they are dry ( i am letting the vapor out just in case) (i checked for spark and it's not getting spark at all, I made sure to ground the plug as I tested as well) the injector is also not pulsating.
I have checked all the fuses and relays (they are all good)
I checked if the engine was actually turning through putting my thumb on vaccum hose and it is turning.
Wondering if anyone had the similar issue or any suggestions to try next.
UPDATE: FOUND THE ALTERNATOR HAS ALSO GONE BAD AND IT WAS SEIZED SO HAD TO REPLACE THAT AS WELL.
What’s the green key indicator in the dash doing ?
P
Seized alternator? I am surprised the belt did not smoke. No spark is either a bad crankshaft sensor, or bad camshaft sensor. Double check the fuses.
1 - 3 of 3 Posts
