Hi. I have a 2007 Honda Accord LX V6 with about 192,000 miles. I was having problems with the car's ac for a couple of seasons. Over time, I wasn't getting any cold air in the cabin. I had the ac compressor and the expansion valve replaced spring 2022 and the ac system recharged and brought to the correct level (by two different mechanics). I changed the blend door actuator myself. The heat works. I did the hvac diagnostic and it did not produce any codes. A mechanic ran a uv leak test and no leaks were found. I replaced the cabin air filter myself. My ac is not dual climate control.
So even with this work complete, the ac still only seems to work with fan on a low setting (the hot/cold dial set to max cold and the fan at only one of the low settings), otherwise no cold air. More cool air comes from the passenger side, but I have had the refrigerant level checked twice, so I don't think it is a low refrigerant issue. So the ac is technically working, not well at all.
I think the main parts of a car's hvac are the compressor, condenser, expansion valve, evaporator, receiver-dryer and refrigerant. So I figure it's got to be one of those parts, and the compressor and expansion valve are new, the refrigerant level has been checked. No one has identified a problem with the condenser. The only other part i can think of that may need to be replaced is the evaporator. Does this sound right to you? Replacing the evaporator looks beyond my skill level, so I would have someone else do it. I think the compressor was shot, so replacing it was not a waste, but I just hope that replacing the evaporator completely fixes the ac problem.
Any ideas?
Any ideas?
