I would clean the IAC and the Throttle Body, as well as doing a valve adjustment. Be sure to check for a vacuum leak as well, may be a cracked hose or intake gasket that does not open up until the temperature rises.
Car has an electronic throttle body(ill check it out) and I don't believe it has an IAC like pre 2008 honda'sI would clean the IAC and the Throttle Body, as well as doing a valve adjustment. Be sure to check for a vacuum leak as well, may be a cracked hose or intake gasket that does not open up until the temperature rises.
