1 - 4 of 4 Posts
EX-L, no Navigation
Have been through the system as I understand it and am stumped.
Fuses and relays ok
Defog light does light up
Green wire (C304) behind left kick panel has 12 volts with Defog on
Took off right rear panel to get to the ground on window as I'm told sometimes it comes loose. Can't see the ground connection, but tested connection to window and chassis and get no voltage. Did I miss something?
Hope someone has something else for me to try.
Thanks
No voltage on the passenger side connector is the normal state but it is also the state if it is open.
When on: do you have 12V from driver's side connection at defogger to chassis ground?
Do you have 12V from driver's side to passenger's side?
1 - 4 of 4 Posts
