Hey all.
Getting an error on my old now my mom's Accord. It's a 2008 with the K24 motor. I got the following codes with a flashing SES light and a VSA and traction control off light. Also the car seems to stumble past 2,500 rpm I am assuming it's in limp mode. It's not being driven at the moment.
P0339 - Crankshaft Position Sensor A Circuit
P0302 - Cylinder 2 Misfire Detected
P0303 - Cylinder 3 Misfire Detected
P0300 - Random/Multiple Cylinder Misfire Detected
I searched and found this link http://www.driveaccord.net/forums/showthread.php?t=42184&highlight=p0339
I went ahead and replaced the battery because it was ancient and needed replacement anyways. Still having the same issue, so replace the sensor? Any ideas?
Here is the code I pulled;
I also checked the sensor and wiring to see if anything was out of the ordinary. Looks fine, the sensor will be here soon and we will go from there. Too bad no one has the crankposition sensor in stock, I had to call 4 places just to find spark plugs.
