yeah that^^^^^!!!!!!!!!!!!!!!!!!!!! hahaha....
Front 20mm
rear 25mm
you should be good thenwell mine only drop an inch had the Honda Sports Suspension Kit. Im good with that.
+1:thmsup:Front 20mm
rear 25mm
This page from Ichiba explains whether or not your need to saw those down... (usually with 20mm spacer or less...depends on application)I'll slide this question in here.
When using a spacer, it comes with new studs. So after we install it, bolt it down, we would have to saw the old stud off, the part that stick out past the bolt?
*I assume it will stick out. Never seen one.
