My brother and I decided to change his stock bulbs to the more yellow Nokya 2500k bulbs. Here's a quick tutorial to assist on changing them out in what we found to be the quickest and easiest way of changing those bulbs. Overall it took about 5-10 minutes to do both sides and take pictures along the way.
Things you'll need
1. Philips screw driver
2. Flathead screw driver
3. Recommend Gloves because you may accidentally touch the bulbs and you'll see where and why.
Passenger Side (Easiest)
1. Start by turning your wheel all the way to the left.
2. From here you'll see two screws to be removed. I broke the one on top for both sides because I was a little annoyed. My fault but easy to replace so take your time on them.
3. From here all you need to do is pull the lining towards the wheel and hold it in place. Don't worry damaging it, I was able to bend it almost at a 90 degree angle and it went back into shape without issues.
4.You can see the bulb from here and all you need to do is disconnect the connector and twist the bulb out and replace it with your new bulb. Then remember to reattach the connector. Finally just push the lining back in and replace the necessary screws and you're done on this side!
Drivers Side
1. Same deal as the passenger side. Turn the wheel this time towards the passenger side.
2. Remove the two screws located next to the wheel.
3. Now you'll need to go under the car directly below the headlight and locate these two screws/clips. To remove them insert a flat head into one of the openings and pull straight down and it should come off in two pieces. You can see one partially removed already.
4. Now to remove the bumper. To do so grab the corner closest to the wheel and pull towards you gently. You'll hear popping sounds but it's the clips releasing from the car.
5. Here's an additional picture to show how the clips look like and be cautious of how far you can pull your bumper. We were able to pull it about 7 inches away from the car without issue.
6. Finally you can see the light bulb. The easiest method I found was to disconnect the bulb first then replace the new one in. As noted before don't forget to reconnect the bulb! Then all you need to do is push the bumper clips back into place and replace the necessary screws/clips and you should be done.
Here's the finished product.
And the victims of being impatient.
Things you'll need
Drivers Side
