1 - 3 of 3 Posts
I would like to get some advice from someone here who has the knowledge.
I was planning to buy 19x10.5 all around my car but... will I need spacers or adjust the suspension?
Can I go 19x9 front and 19x10.5 rear???
Or should I go 19x9 all around?
Please, your advice will be appreciated.
Offset makes the difference for example my 20” rims are 8.5” wide offset “et”35 and stick to the edge of the fender Lip if I lower my car 2.5” I will have to pull the fenders slightly and slight camber keep in mind camber wears tires faster, which is why I’d rather pull the fender than camber like hell. And I’d also think your front fender liners will need to be modified for the 10.5 I may be wrong and tire Size dependent aswell I would think you would need an offset of 50 ish for 10.5 don’t quote me but if I remember correctly by how offset works
CVT
It's possible when all the pertinent factors are taken into consideration. Will need to know information such as tire size, offset, backspace, and ride height you'll be using.
1 - 3 of 3 Posts
