Our 2013 recently encountered a problem where the car will not start and instead go into Accessory mode. It can sometimes take 8 or 10 presses of the start/stop button to get the car to finally start. This only happens once every several days.
We took it into a trusted shop. First they replaced the brake switch after a full diagnostic (battery, alt, starter) revealed no issues. That didn't help so they replaced the starter - then when we went to pick it up it wouldn't start right away (at least I was able to show them the issue since it wouldn't do it for them).
I see others with a similar issue here solved it with a new starter. Any ideas what else I can suggest? I bring it back in soon when their master tech is working so he can look at it again (they mentioned at least swapping the starter for another). Thank you!!
Mark
Mark
