HELP! I have a 2013 accord which i really like. 120k. I have had the o2 sensors changed twice because after awhile it throws the code which is for the o2 sensor and the mechanic changes it. Have had the spark plugs changed. And now i get this p0420 code for the cat. Took it to another mechanic, he says the cat needs to be changed. Well I know it's for the cat, but doesn't always mean it's that. Could be something that is causing this. Below I will show recent maintenance that has been done. I suspect the quick carbon buildup on o2 sensors have something to do with this code now. I don't know what is causing the o2 sensors to go bad so quickly.
Could it really be the cat? I was quoted at $1000 for a new one with labor. But last thing I want to happen is pay that and the p0420 code doesn't go away...
4/12/21 108,653
- o2 sensor upstream rear: Denso 234-5056
- o2 sensor downstream rear: KAX 250-24785
6/2/21 110,177
11/8/21 115,036
- o2 sensor upstream front: Denso 234-5056
12/27/21 116,122
- o2 sensor upstream rear (2nd time): Denso 234-5056
1/27/22 116,455
- o2 sensor: upstream front (2nd time): NTK 24372
THIS IS WHEN THE P0420 NIGHTMARE STARTED
5/3/22 118,826
- o2 sensor: upstream front (3rd time): Bosch 18083- P0420 STILL HERE
4/12/21 108,653
6/2/21 110,177
- o2 sensor downstream front: Denso 234-4781
- Spark plugs: Bosch 9619
11/8/21 115,036
12/27/21 116,122
1/27/22 116,455
5/3/22 118,826
