Looks like my wife is due to have the brakes replaced on her Accord Sport. Pads are thin and she has a slight pulse when stopping. Looking for a oem equivalent pads and rotors. Any suggestions? Nothing fancy it's just the 4 banger. Thanks.
you can check rockauto.com for rotors and recommend sticking with OEM pads. I've purchased in the past the "oem equivalent pads" to only end u with noise issues.
The backing plate would always separate from the pads. at the end OEM pads arent that much more compared to the generics.
but you can also get oem equivalent pads at rockauto or even autozone. I think they have some duralast gold for 30 bucks for Front and 30 for Rear.
are you changing out the fronts or rears? Akebono is also a brand worth your consideration.
As for rotors, I will defer to others. I got Centric rotors on my 7th gen the last time. My perception was that the factory ones were better.
I'll second the recommendations here for OEM pads and rotors. I've gotten great wear out of mine. Of course, I don't abuse my brakes either, particularly by doing max-effort stops at intersections and then leaving the brakes applied.
