I recently paid off the car, so I'm moving forward with something I have wanted to do since I bought it. The car is a 2014 Accord EX-L V6 Sedan, and I am going to yank the automatic transmission out and replace it with the 6-speed manual. As far as I can tell this might be the first time this has been done on this car so I'm not finding a lot of exactly relevant information for this project. But I'm going to go ahead anyway and make it up as I go. I got other ways to get around town so it's not a big deal if the car is down for an extended period of time while I tear into it and fix the bugs that will inevitably pop up along the way.
I found a 6MT transmission from a 2012 accord V6 coupe at a local auto recycler. I'm gonna start with that. In addition to the used transmission, it looks like I'm going to need:
- new axles
- new front and rear engine mounts
- new transmission mounts
- new clutch pack
- used clutch pedal
- used clutch master cylinder
- used manual transmission brake pedal
- used shift linkage
- used flywheel
- used starter motor
I am worried about the wiring harness and ECU. My original plan was to take the 6MT engine wiring harness from a donor V6 coupe and ECU and move it into my car along with the transmission, but it looks like the V6 sedan and V6 coupes actually have different revisions of the J35 engine. The V6 sedan has the J35Y1 (VCM) and the V6 coupe has the J35Y2 (non-VCM). This makes me worry that the 6MT ECU for the coupe’s J35Y2 may not properly drive my sedan’s J35Y1.
So now my current plan is forming around leaving the sedan’s automatic transmission ECU and wiring harness in place and running it with the manual transmission. This poses its own problems, but I think I can solve most of them. The car won’t start unless it is in park, but I figure I can rig that sensor to my parking brake so the ECU thinks it is in park and will start with the brake engaged. The rev limiter is set to around ~5,000RPM in park, but that problem also goes away if the park gear sensor is rigged to the parking brake – let the parking brake down, ECU thinks it is out of park and in drive.
Question: If I leave the current ECU from the stock automatic transmission powered car in place with the manual transmission, what kind of check engine codes should I expect? Will this generate any check engine lights for missing sensors from the missing automatic transmission? Are there any easy ways to bypass these missing sensors?
Couple of pictures of the car before I tear into it:
- new axles
- new clutch pack
- used clutch pedal
- used flywheel
